Avensis key replacement
mark0
Hi lads bought a replacement key off Amazon looks exactly the same as master key with remote and transponder chip when I go to program both the transponder and remote it fails to program I am using techstream version 13 when it’s on the register screen it counts down to from 70 secs gets down to 10 secs then says operation fails ecu fail to communicate with key
It is likely to be a different transponder chip version.
Yes I was thinking this aswell the 2008 t25 transponder chip seems to be hard to get
