Avensis auxiliary belt slip
RDP
Hello all,
I own a 2012 Avensis, 2l D-4D, which has had an ongoing issue with the auxiliary belt - it makes a slipping noise when I accelerate, normally in a high gear (60mph 6th gear). I’ve had the Toyota garage look at it a few times and the temporary remedy has been to re-tension or replace. But the slipping resumes a couple of months later.
Any ideas what is causing the tension to slacken or why this is happening at all?
Thanks in advance.
Richard
There was a Technical service bulletin for something similar:
EG-0014T-0114
Subject: 1AD-FTV V-Belt abnormal noise
Models: AURIS; AVENSIS; COROLLA; VERSO
Model codes: ADE150; ADE157; ADE186; ADT250; ADT251; ADT270; ADT271; ADE150; AUR20; AUR21
DESCRIPTION OF PHENOMENON Some customers may experience and report squeaking noise from BELT, V-RIBBED around 1500~2000rpm, due to slipping of the belt on the pulleys.
PRODUCTION CHANGE The design of the BELT, V-RIBBED has been changed to avoid slipping.
PARTS INFORMATION Previous part number 90916-02724, Current part number 90916-02736
REPAIR PROCEDURE
1. Check the ''TENSIONER ASSY, V-RIBBED BELT'' after disassembling the BELT, V-RIBBED according to the repair manual.
2. In case of abnormality of the ''TENSIONER ASSY, V-RIBBED BELT'', replace it. If no abnormality is present, then do not replace.
3. Only replace the BELT, V-RIBBED according to the repair manual
You say you have had a new belt, do you have an invoice, what part number belt was used? as the bulletin is a field fix only and was not included into production it is possible the dealer hasn't seen the bulletin so may not have used the modified belt
  • 1 year later...
EG-0014T-0114
REPAIR PROCEDURE
Thanks!!!! It helped me a lot with a problem with more than a year. Same engine but in a 2011 Verso. Perfect!!!!
