Wanted the windows to go up when I put the central locking on
Rang helpful local dealer and he said they should be able to programme it with their tech guy.
They do it on other toyotas like the Ch-v so shouldn't be a problem on the 2019 corolla sports wagon
Booked in on monday to have it done at no charge.
Will let you know if sucessful
I just had this done on mine today. Window closing is not automatic when you lock with a quick key press but if you press and hold the lock button for a couple of seconds the windows will then all go up... which is what you are wanting, I assume?  Likewise they all go down (as far as you want) when you press and hold the unlock button.
My dealership didn't know about this tweak until I told them and it's taken me a while to persuade them it's possible - I've had the car two months. The service guy who did it today said I was the first customer to ask for it. It's just a setting on the computer - easily done and there was no charge. Apparently Toyotas aren't usually equipped with this feature so it's a new procedure for them.
Ah well, they got some good practice in on my car today and will know for the future! 😄
That's great thanks
They also said they can disable the seatbelt chimes for specific seats
2 hours ago, Cbatoday said:
That's great thanks
I wonder what else can be programmed by the dealer!
Thats nice.
But having this done by my dealer could be a bit tricky and im sure the answer I will get is big NO.
There are loads, most are very boring and the best I have found are:
Remote open/close windows
Auto rear wiper when front wipers operating and reverse is selected, can be set ON/single wipe , ON/constant wipe , OFF
Unfortunately there is no overall list published only small charts of customisations listed under each possible selection e.g lights, locks, Windows , Nav, AC etc, etc. and it would take days to try on collate all of them.
Here are lighting options for a Hybrid HB the first chart is settings via Diagnostic computer (GTS)
    1.
      Tester Display
      Description
      Default
      Setting
      ECU
      Lighting Time
      Changes the lighting time of the following lights that are operated by the timer function when the map light assembly door linked switch is on, room light switch LH and room light switch RH of the room light assembly are on*4, and the rear room light (No. 1 room light assembly) switch is set to DOOR*3:
      • Map light assembly
      • Rear room light (No. 1 room light assembly)*3
      • Room light assembly*4
      • Front door ambient illumination light (Front door trim board sub-assembly)*1
      • Rear door ambient illumination light (Rear door trim board sub-assembly)*1*5
      • Center tray illumination light (Instrument panel light assembly)*1
      • Cup holder light (Console box pocket garnish)*1
      15 s
      10:30 s,00:15 s,01:7.5 s
      Main body ECU (Multiplex network body ECU)
      I/L when ACC OFF
      Lights up the following lights automatically when the map light assembly door linked switch is on, room light switch LH and room light switch RH of the room light assembly are on*4, the rear room light (No. 1 room light assembly) switch is set to DOOR*3, and the power switch is turned from on (IG) or on (ACC) to off:
      ON
      0:OFF,1:ON
      I/L ON W/Door Key Unlock
      Lights up the following lights automatically when the map light assembly door linked switch is on, room light switch LH and room light switch RH of the room light assembly are on*4, the rear room light (No. 1 room light assembly) switch is set to DOOR*3, and the doors are unlocked by an unlock operation:
      ON
      0:OFF,1:ON
      Room Light when Aprchd
      Lights up the following lights when the map light assembly door linked switch is on, room light switch LH and room light switch RH of the room light assembly are on*4, the rear room light (No. 1 room light assembly) switch is set to DOOR*3, and the electrical key transmitter sub-assembly is brought near the vehicle*2:
      ON
      0:OFF,1:ON
      Inside Foot Light
      Turns on the following lights:
      ON
      0:OFF,1:ON
      Light Control
      Dims the following lights when the power switch is on (IG) and the shift lever is moved to any position other than P:
      ON
      0:OFF,1:ON
      Interior Light Control
      Lights up the following lights:
      ON
      0:OFF,1:ON
      Interior Illumination Light
      ON
      0:OFF,1:ON
      • *1: w/ Ambient Illumination Light
      • *2: w/ Entry Function
      • *3: w/ Room Light (for Slide Switch Type)
      • *4: w/ Room Light (for Push Switch Type)
      • *5: for Sedan or Wagon
  1. Customizing with the multi-display
    1. Turn the power switch on (IG).
    2. Enter the following menus: MENU / Setup / Vehicle / Vehicle customisation / Lights settings.
    3. Select the setting by referring to the table below.
      Display
      Default
      Content
      Setting
      Relevant ECU
      Interior Lights Auto-off Timer
      15 sec.
      Changes the lighting time of the following lights that are operated by the timer function when the map light assembly door linked switch is on, room light switch LH and room light switch RH of the room light assembly are on*3, and the rear room light (No. 1 room light assembly) switch is set to DOOR*2:
      • Rear room light (No. 1 room light assembly)*2
      • Room light assembly*3
      • Rear door ambient illumination light (Rear door trim board sub-assembly)*1*4
      Off, 7.5 sec., 15 sec., 30 sec.
      • *2: w/ Room Light (for Slide Switch Type)
      • *3: w/ Room Light (for Push Switch Type)
      • *4: for Sedan or Wagon
Here are window settings for a Hybrid HB
  1. Power Window
    Tester Display
    Description
    Default
    Setting
    ECU
    Door Key P/W Up
    Function to close the power windows using the mechanical key
    OFF
    0:OFF,1:ON
    Door Key P/W Down
    Function to open the power windows using the mechanical key
    OFF
    0:OFF,1:ON
    P/W Up W/ Transmit
    Function to close the power windows using the key
    OFF
    0:OFF,1:ON
    P/W Down W/ Transmit
    Function to open the power windows using the key
    OFF
    0:OFF,1:ON
    D Window Auto Up
    Function to enable or disable the auto up function for the driver door power window using the multiplex network master switch assembly.
    ON
    0:OFF,1:ON
    Front door window regulator assembly (for Driver Door)
    P Window Auto Up
    Function to enable or disable the auto up function for the front passenger door power window using the power window regulator switch assembly
    ON
    0:OFF,1:ON
    Front door window regulator assembly (for Front Passenger Door)
    RR Window Auto Up
    Function to enable or disable the auto up function using the rear power window regulator switch assembly (for RH door)
    ON
    0:OFF,1:ON
    Rear door window regulator assembly (for Rear RH Door)
    RL Window Auto Up
    Function to enable or disable the auto up function using the rear power window regulator switch assembly (for LH door)
    ON
    0:OFF,1:ON
    Rear door window regulator assembly (for Rear LH Door)
    P Window Auto Up From Driver
    Function to enable or disable the remote auto up function for the front passenger door power window using the multiplex network master switch assembly
    ON
    0:OFF,1:ON
    RR Window Auto Up From Driver
    Function to enable or disable the remote auto up function for the rear RH door power window using the multiplex network master switch assembly
    ON
    0:OFF,1:ON
    RL Window Auto Up From Driver
    Function to enable or disable the remote auto up function for the rear LH door power window using the multiplex network master switch assembly
    ON
    0:OFF,1:ON
    D Window Auto Down
    Function to enable or disable the auto down function for the driver door power window using the multiplex network master switch assembly
    ON
    0:OFF,1:ON
    P Window Auto Down
    Function to enable or disable the auto down function for the front passenger door power window using the power window regulator switch assembly
    ON
    0:OFF,1:ON
    RR Window Auto Down
    Function to enable or disable the auto down function using the rear power window regulator switch assembly (for RH door)
    ON
    0:OFF,1:ON
    RL Window Auto Down
    Function to enable or disable the auto down function using the rear power window regulator switch assembly (for LH door)
    ON
    0:OFF,1:ON
    P Window Auto Down From Driver
    Function to enable or disable the remote auto down function for the front passenger door power window using the multiplex network master switch assembly
    ON
    0:OFF,1:ON
    RR Window Auto Down From Driver
    Function to enable or disable the remote auto down function for the rear RH door power window using the multiplex network master switch assembly
    ON
    0:OFF,1:ON
    RL Window Auto Down From Driver
    Function to enable or disable the remote auto down function for the rear LH door power window using the multiplex network master switch assembly
    ON
    0:OFF,1:ON
  2. Enter the following menus: Customize Setting / Wireless Door Lock.
    Wireless Door Lock
    Tester Display
    Description
    Default
    Setting
    ECU
    P/W Wireless Ope Buzz
    Function to turn the wireless power window buzzer response on or off
    ON
    0:OFF,1:ON
  4. Enter the following menus: Customize Setting / Security.
  5. Select the setting by referring to the table below.
    Security
    Tester Display
    Description
    Default
    Setting
    ECU
    Window Open Warning
    Function to enable or disable the window open warning
    ON
    0:OFF,1:ON
That's a lot of customisation
Have been to the dealers to have my windows to be programmed to go up automatically when I hold the lock butto
Great improvement
For so long now  I have been asking my dealer about this customisations and none of the technicians know how to do it
Try asking another dealer
I asked my dealer to do the windows setting on my RAV4 before it was delivered in May.  They also said I was the first to ask for it and that they hadn't been aware before.
I now realise I could have had it done on my last car too, a 2016 Prius.  From the way it was worded  in the manual, it could have been only available on cars with the sunroof (it opens closes the sunroof too, if fitted), but this time I asked them to check and I'm glad I did.  In the current weather it's nice to get all the windows open as soon as I'm in remote range, so the worst of the heat has escaped before I jump in the car.
Just a shame we can't have ventilated front seats like the US/Canadian (and no doubt other) market models.
Got it done at last by the service manager. How come the technicians doesnt even know how to do it. It only took atleast 3-5 mins to be done
08C30BDB-307C-4E88-86A7-EA32397644A3.MOV
Not training I would think
I took my Corolla to my dealership and they programmed it open and close the windows including the pan roof it took  less than 10 minutes to do.
I had the windows open/close  with the keyfob programmed at the dealers.
Asked for auto locking doors when moving. Not possible on this model. Basic security !!
