Aygo (2015) infotainment upgrade Android Auto and Apple Carplay
The one you desire, do you want DAB (digital radio) or not, those versions are meaningless
On 9/9/2022 at 8:22 AM, TumbleNL said:
so i am beginning to believe my car doesnt have a microphone installed.
Hoi Eelco,
which was the original radio that came with the car? As far as I know all base models came with a radio including bluetooth connection to stream audio and make calls. It also doesn’t make sense that you got the steering wheel buttons without the microphone… Maybe a loose pin in one of your cables behind the unit?
7 hours ago, jefjb said:
Ok which must i order?
i saw some release v1.0 (no DAB model) v1.2 and v2.0. (DAB model)
what are the differences?
As mentioned by @flash22 the only differents between the two is the DAB radio. If you choose for DAB you should get two cables (which are hard to find and remove the dashboard to install the dab cable to the antenna.
You can also choose to get an aftermarket antenna and install it behind the air vent on top and in the middle of your dash. The reception would be less when compared to the oem installation… scroll to this topic to see which adapter cables and antenna you need.
Hi, I fitted the two button unit but my mic isn't working, driving me mad! I've checked and I have the mic but on the diagnostic test screen it's  not hearing me. I'm assuming it's one of the wires at the back of the unit. Does anyone know what and were that wire is on the back of the 2 button unit so I can double check. Thanks in advance people 👍🏼
Is the factory mic fitted ?? the base radios do not have them (mic is beside the interior light)
Yes, I have the mic, just not working. Just wanted to check what I should be looking at at the back of the unit. Thanks
See the thread i linked to.
Wouah ! You have electrial drawings for this unit! Maybe you can tell me what are the newest software release of the 86140YV010 ?
For this unit, i saw 3 kind of sofware remease directly printed on the unit: V1.0; V1.2 and V2.0?
Maybe you know what are the differences between these 3 software?
The above diagrams are for the 2 button xtouch (not my pic's) - i have full diagrams
1.0/1.2/2.0 don't mean a lot tbh, it's just the base software installed during manufacture
the only update at the moment that is available is 8.12/8.15/8.17
Ok and thanks for these informations.
i will receive my new unit instead of the first touche screen generation.
if i have old update, is it possible to update it?
Yes, the update is done with a USB stick, i have this update if required
Thanks pal, I'll take a look!
Hello
i just received my new unit.
the only thing  is this is a DAB model.
So does radio work with classic antena?
must i change my antenna et for which kind of model? Do you have a link to buy it?
For sure, i desire having good radio reception.
Ik heb dit gedaan, maar het werkt niet erg goed
2 hours ago, kachel said:
I did this but it doesn't work very well
What doesn't work well ?
3 hours ago, jefjb said:
Hello
FM/AM aerial is the standard oblong white plug. The DAB uses its own connection
Posted (edited)
So after installing my new unit, i confirm i  can use original antenna and DAB antenna. So i do not have DAB antenna and i just plug original antenna tonly unit.
it works very fine!
For informations, my unit is this
Edited by jefjb
Correction
Does these units have secret mode and what is the operations to restart the screen?
yes they have a hidden service menu
Mk2 Aygo hidden service menu
Turn the ignition on - Press and hold the bottom physical button, Turn the headlights on and off 3 times
Do you see, when you switch on and switch off your light, a brightness difference?
And this difference is big or small?
4 hours ago, flash22 said:
Wat werkt er niet goed?
Slechte DAB ontvangst
If it's a cheap aftermarket aerial they do not work very well, location is important too, there are 2 types of factory aerials and bases and the wiring requires changing
we are a UK forum, 99% is posted in English, very few members run translator plugins like myself
Just try to get a factory cable and open up the dash…
Also: Only use English since it an english forum, .co.uk not .nl 😉
 I have an iPhone . Is there any hope of getting SMS to work? At the moment I click on the picture of the envelope on the touchscreen phone section and it brings up a box asking me if I want to set it up now. Then it says 'waiting for device' and nothing happens until eventually it just seems to timeout and go back to the same screen.
