Aygo (2015) infotainment upgrade Android Auto and Apple Carplay
I have the 86140-yv020. In the Connection Settings menu there is an option called "Connect MirrorLink Wi-Fi". However I don't see an accespoint on my phone. Do you need a separate module for this or should it be build-in the radio?
Broekhuis
Good morning to everyone.
I'm looking for my 86140-YV020 the latest update available.
I think the target version Is:
Audio: 814
Operating system 1: 8.34
Operating system 2: 8.59
Can someone send me a link?
THX in Advance
On 12/29/2022 at 3:00 PM, Arie Bart said:
Broekhuis
mirrorlink is dead and only a handful of phones still support it
Audio: 814
THX in Advance
That is the current factory version, looking at the OS 1 and 2 the unit is from a late C1 or 108
Yes. I take It on eBay from a C1: my Aygo in origin has the x-touch...
Now my stereo run correctly but with Android auto there Is some issues: during call i'm unable to hear nobody.
This issue appears randmly...
My actual version Is:
0S1 8.15
OS2 8.17
it's still a current version
did you wire in the microphone, as some cars didn't have them
Yes of course. This issue occurs only sometimes only on incoming calls
Audio: 814
THX in Advance
Hello,
I have 8.14 version. How can i update?
5 hours ago, jefjb said:
Hello,
8.14 is current, no others are available apart from the newer versions that come from the factory
Ok, sorry  i was sure that other update exidted
There are newer versions of the software, but they are not available as a TSB, there are a few variations of the software depending on what car the unit come from/what car it's in
Hello,
Recently upgraded my aygo radio to the 86140-yv020. Just checked and my radio is showing the following versions:
Audio: 8.10
OS1: 8.10
OS2: 8.14
Is there a possibility of receiving a software update?
Thanks,
Mark.
2 hours ago, Mark_C said:
Hello,
Audio: 8.10
OS1: 8.10
OS2: 8.14
Thanks,
Mark.
If you send me pm I can send it a PDF where you can download an upgrade...
Thanks, PM sent 🙂
Does the upgrade add anything other functions? Or just bug fixes ?
Not that I've seen any bugs on mine....it's pretty stable.
It's more of a patch, 8.12 fixes a lot of stability issues
  • 4 weeks later...
Hi all, I'm new to the forum.  I recently purchased a 2017 Aygo X-Style with X-Nav.  I've just bought and fitted the three button multimedia head unit but can't get Carplay to work.  Basically, the options to enable Carplay and Android auto are not displayed in the relevant menu.  Is this due to incompatibility with X-Nav or is it some other issue?  I would have thought the menu options would be there.  Any help would be much appreciated.
Xnav does not work with the tripleplay disconnect it and plug the usb into the tripleplay directly
Thanks very much.  Any idea which plug in the back of the head unit is the X-Nav connection?  Blue plug?
You will find a USB cable that goes from the radio to a black/grey box - 3 connectors in total 1 to the radio, one to the usb and the other goes to the sat nav
Unplug B (yellow) and plug it into the radio
Hi All,
I am new to this forum but see some questions about my radio
I bought the 86140-YV020. Everything works except the dab+ radio. I bought an antenna on the internet, but i doesn't work. No service says the display. I think i must use the blue connector on the back side of the radio for DAB+.  Has somebody a link for me for a dab+ antenna with the blue connector? would be great, because i am about to give up.
I put some pictures in the post to let you see what i mean.
52 minutes ago, Techfreak said:
Many thanks Techfreak for the quick reply.
So I plug the grey connector in the blue? and does the golden plug fit into the other golden plug of the antenna?
I just zoomed in on your photos......
Sorry no....to keep things simple to connect to the adaptor cable you need this Antenna...
https://www.ebay.co.uk/itm/174333137475?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=v59d1fnkq0g&sssrc=2349624&ssuid=0v63jnXjRZa&var=&widget_ver=artemis&media=WHATS_APP
Many thanks Techfreak. This seems to fit and work. I will order this. to be continued.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
