Aygo (2015) infotainment upgrade Android Auto and Apple Carplay
50 minutes ago, flash22 said:
It's plug-and-play, only base models without Bluetooth will require the factory Mic
please read the first page of this thread
I've read all the threads I could find, the touchscreen has some ports which the radio do not have, that's my question! I even checked YV010 vs 20 in case the DAB was the difference
YV010 is without DAB
YV020 is with DAB
the extra 8-pin connector is for the reverse camera, if you want dab you will need a DAB Aerial
information is in this thread
YV020 is with DAB
Yeah the DAB thing I understood. That's what I wanted to know, what the extra 8-pin connector was, if it was in this thread, I must have missed it. Thanks flash!
posted the info in a few threads, but here is a cut and paste...................
the 8 pin is for the camera
you can get retention adapters
Warning !!, Do NOT wire 12v to the camera plug as the camera is 6V
This is the socket view or wire side of the plug
Pin 1 - 6v to camera in reverse
Pin 2 - Video signal +
Pin 5 - Negative
Pin 6 - Video signal -
  • 4 months later...
Hi group,
I have Peugeot 108 2019 with following version:
ID model: 18PPDAEU-EA01
86140-YV020
Audio:      8.10
Sysstem 1:  8.10
System 2:   8.14
Who can help me with software update files to do it and have Carplay and Android Auto on this system.
Thanks in advance.
Hello, I just removed the head unit with 2 buttons to the one with 3 buttons but the USB port is not working anymore. The phone is not even charging. I don't have X-Nav. Should I update my firmware? The problem is then how if the USB is not working. Just to confirm, if the USB is working with the old head unit it means that is a problem of the new one correct?
that is current firmware, make sure the USB cable comes from the USB port directly to the back of the radio and not to a box at the rear left behind the radio (post a pic if you are unsure) - you need a working USB port anyway to install the update
these radios turn up from time to time on  eBay, Facebook and the like, what the dealers have swapped out under warranty and have been liberated and not tested fully
I have an Aygo 2015 with a Apple Carplay radio which keeps rebooting while using GoogleMaps.
My software is:
Audio: 812
OS 1: 8.15
OS 2: 8.17
Is there anywhere a possibility to download more up-to-date software?
what is the model number YV010 or YV020
Hello there, does anyone have the files to update to the latest version ? I am searching everywhere but I can't find anything...
Mine says  :
Hard No. : 86140-YV010
Audio : 8.12
Operating system 1 : 8.15
Operating system 2 : 8.17
I also want to ask if anyone knows why when I use Carplay it continues to restart … like around every 2 minutes and does anyone know how to fix it ?
I hope I can get some help.
Thank you. so much
that is current firmware, change your USB cable to a decent quality one also make sure your phone is fully charged and all apps are up to date, turning off bluetooth can help
So this problem is kinda normal for everyone ?
because if it is a hardware fault I can send back the product and ask my money back …
