Aygo (2015) infotainment upgrade Android Auto and Apple Carplay
Hello,
I have a new headunit (86140-YV020) where do I download the firmeware updates from?
T.I.A
Tony
On 12/22/2020 at 7:29 PM, BobbyMcLeish said:
Can someone tell me where this cable is for? I don't have this cable in my Aygo (x-fun aygo).
is it the 8 pin connector ? If so its for the rear camera its just plug and play
ps. I also see you only have front Speakers
I’ve just fitted the new headunit (86140-YV020) in my Aygo as well however the touch to speak button doesn’t work (can’t hear me) but I can still speak over bluetooth calls. Does anyone know why this might be?
ps. I also see you only have front speakers
Thanks flash22 for the fast reply. I don't have a rear-camera (so I hope the cable is for the rear-camera). If I place a multimedia system I don't want to lose functionalities.
29 minutes ago, Sjbla said:
I’ve just fitted the new headunit (86140-YV020) in my Aygo as well however the touch to speak button doesn’t work (can’t hear me) but I can still speak over Bluetooth calls. Does anyone know why this might be?
This is actualy where I'm afraid of. I have a Aygo x-fun and want to place a multimediasystem. I hope someone here has an answer for you.
On 1/21/2021 at 5:41 PM, twebb8 said:
Hello,
T.I.A
Tony
I found this in the aygo-manual. Here is a link: http://stream.toyota-motor-europe.com/aftersales/NAVI/MM/Aygo/XTOUCH+RC1+software+update.zip I don't know of this is the lastest version and of this is for the 86140-YV020 version. Please read the manual first.
My daughter hasn't bothered with that function, but I rember reading that you have to specifically pair your phone properly for that to work. If you search the forum, I'm certain someone posted the full user manual
  • 3 months later...
Hello
I am very confused....does the 86140-0Y070 unit support Apple Carplay ? It only looks like it has 2 buttons but I read that all 2019 models onwards support CP ?
Confused.com
If the headunit doesn't have the three buttons, it won't have CP or AA.
Is 86140-0Y070 the correct number as it comes up as not found  - 86140-0H070 is the standard touch screen (no AC/AA) there is also 19 onwards 86140-0H071
Specs depend on your location and the car's specification, it may have been an option when new
22 hours ago, Whizzkid said:
Hello
Confused.com
When the facelifted Aygo was introduced in the UK in 2018, there were two multimedia units - a two button unit without smartphone integration fitted to the lower specs, and a three button unit with smartphone integration (basically Apple Carplay & Android Auto) fitted to the higher specs.
The Aygo range was revised last year(?) and as far as I'm aware, they come with the three button unit as standard now.
Your profile doesn't state whether you are in the UK, so, if outside the UK, specifications may be different.
As of DEC 19 it was standard on the whole range excluding the Base x model and all 3 door Cars - so if the 3 door cars didn't get AA/AC they must have the standard X-Touch (Aygo X gets the Standard cd/radio with 2 speakers)
Jan 19
Dec 19 - *AA/AC Not available on 3 door
April 20 *AA/AC Not available on 3 door
2019 onwards x-touch 86140-0H071
eg. https://www.ebay.co.uk/itm/154413635651?epid=24039762092&hash=item23f3c51843:g:7HwAAOSw~Ktgdf1a
Hello, I am looking for this connector, does anyone know where I can buy this connector or possibly a complete dab antenna?
Did your Aygo come with DAB? If not, then the DAB antenna probably won't be fitted at the factory.
You have 2 options either fit a good aftermarket DAB aerial or change the factory fitted one to one with DAB
The DAB connector is Toyota specific, but a standard SMB will fit
eg.Connects2 CT27UV62
I don't think this is going to work, it's a different connection on the radio.
My mistake i forgot it was the square pin type
i will have a look
what is the part number on the radio ? 86140-
86140-yv020
  • 5 months later...
On 12/22/2020 at 5:08 PM, BobbyMcLeish said:
It may be worth taking out the navigation maps SD card which is in the glovebox, this may be confusing the replacement headunit, however, based on what's been said, this function should not work with the replacement headunit !!!
I spent nearly two hours today trying to get this to work.  You will NEVER get the carplay and android Auto to work unless you unplug the little sat nav box which sits behind the unit. (see photo). This applies to the units with the sat nav function.  Once you unplug this, when you use the usb socket in the car and plug your phone in, android Auto and carplay are they.  Works a treat.....finally.
im trying to install the head unit in my car. Everything is working except the Apple carplay and android auto. I’ve tried unplugging the cable for the sat nav box and indeed it will show the Apple car play options in the settings. However, my USB port is not working anymore. When I try plugging the cable from the sat nav box back in, the USB port works again. Can you tell me what I’m doing wrong??
huge thanks
The 3 button head unit with Apple Carp!ay/Android Auto isn't compatible with the X-nav sat nav module - and Toyota discontinued the X-nav module.
1 minute ago, FROSTYBALLS said:
The 3 button head unit with Apple Carp!ay/Android,Auto isn't compatible with the X-nav sat nav module. You either have one (AC/AA) or the other (X-nav).
Ok,
I have the 3 button version. But I don’t need the x-nav functionality. I just want to use Apple carplay. But when I disconnect the sat nav box, my USB port doesn’t work anymore but the 3 button CarPlay unit does now show the CarPlay settings.
23 minutes ago, mildg said:
im trying to install the head unit in my car. Everything is working except the apple carplay and android auto. I’ve tried unplugging the cable for the sat nav box and indeed it will show the apple car play options in the settings. However, my USB port is not working anymore. When I try plugging the cable from the sat nav box back in, the USB port works again. Can you tell me what I’m doing wrong??
huge thanks
X-nav when fitted handles the USB , use THESE to remove x-nav from the system
Thanks,
Do you think if i remove cable "D", it will work? Because the USB cable is still plugged in.
