My radiator cooling fan has died and melted the plastic blades as well, I'm looking at replacements, the number is
16363-0d090
I've seen a lot with the same first number 16363 and slightly different numbers afterwards like 0D070 or 0J020 or 22090 they look similar and have the same 3 screw mounting positions, are they likely to be interchangeable?  even if the Cowl is different my cowl is intact so we could just swap the fan over (with the blades attached)
solved if anyone finds themselves here, most of the corolla and other toyota range in the 1.6 to 1.8 L range have a visually similar cowl, motor and fan, I've got the assembly out of a 1.6 VVTi on my 1.8 VVTLi without issues
