2018 Toyota Yaris USB grayed out.
dlittleton
is there a way to enable the USB on my  info center? I would like to use Android Auto but when I plug the phone in the USB it does nothing on the screen and the USB button stays grayed out.
Pretty sure touch 2 go doesn’t support either android auto or Apple car play.
I suspect the unit also isn’t ‘seeing ‘ your phone as a usb device.  Depending on the type of phone you have it may be possible to set it to ‘storage mode’ so it should see it then.  Android only I suspect, don’t think it’s possible with iPhones.
Which country are you in, as you may have a different multimedia unit to the Touch 2 in Europe (eg Entune).
Hatchback or sedan?
