1988 HiAce 2.0L Petrol - Radiator compatibility?
pdrussel
I'm in the UK and have a 1988 petrol HiAce van (with Devon camper conversion) that's sprung multiple leaks in the radiator. I'm not particularly mechanically minded so patched the hole I was initially aware of with JB Weld only to have a couple more spring up when testing it - RadWeld hasn't helped either as the holes are too big.
Would anyone know if there are radiators that are compatible with a MKII van? Finding a direct replacement is proving hard as they're out of stock at all the sites I've checked.
Also, would a radiator from a Diesel MKII HiAce be compatible as have found some of them?
Thanks in advance for any assistance.
I can't answer your question, but your old radiator could have a new core fitted by a radiator specialist.
