Replacing dual zone for single zone in 2010 1.33 Auris
ChrisRussell22
Hi all
I’m looking to do the swap on the heater/air controls from the dual zone to the single zone in a 2010 1.33 is it a simple plug and play or do I have to change all the other stuff over too?
the dual zone will have a different heater / ventillation unit fitted as it
will have 2 heater matrix's so the driver & passenger can have different temperatures
where the standard system will only have 1 matrix, the standard system will
probaby be controlled by cablesfrom the dials and the duel controlled by motors.
it is a jpb that could be completed but it will be a lot of work to do the conversion
and possibly not worth the effort needed.
by any chance does the system have a dual button as this will let you control
both side independantly or together
Why would you want to go to all that trouble?
If dual zone is not on then it is single zone. Don't select auto and it may all be manually controlled.
