2013 corolla professional does not start but cranks
My toyota corolla would not start but cranks. i checked the fuel pump, injectors, plugs new coils and new MAF sensor the car still is not starting. i have noticed that top gasket is leaking can this be the cause.
Are you getting any eml
Are all sensors connected
i only had a MAF sensor  error code of which i replaced but still it does not start.
Have you checked the wires leading to the maf sensor arent damaged and is connected properly
That i have not checked i will check.
