Hello,
I bought a EAGLE cruise control , it is really a speed controller. It is mechanical and has black and red wire to be connected.
The red wire needs to go to the break light switch, which is connected to a relais inside the cruise control.
So whenever I break this will then automatically shut off the cruise control.
Can anybody tell me which is the Plus inside the break light switch ? (see picture)
I took off the plug and saw two flat pins and two small pins.
I contacted the wire on the big pins, but then the cruise control didnot function anymore and I was not able to switch it on.
Then I did connect it to the small pins and it gave the same result
Can anybody help me with this question.
I am living in Holland and will go on Sunday to Austria, so I hope to have fix this before the weekend.
Regards, Bert
using a multi meter set on 20v dc test between earth on the car and one of the pins
1 pin will be the live side the other pin will be a switched live cable
i.e. only becomes live when the pedal is pressed.
the light earth will be found on the rear light multi plug.
Hi Mark,
Usefull advice !  Althought I didnot use the multi meter, I figured out it was the right big pin which was the switch live pin.
For anybody who wants to build in a cruise control.
Regards, Bert
