Hi Guys hoping someone can shed light on an intermittant speedo problem im having. Speedo intermittantly fails to work. Its a 04 1.4vvti petrol model.There is no speedsensor on the back off the box so i presume its run off the abs. There is no faults located on any of the modules on diagnostic. I have previously replaced clocks before due to fuel guage ,temp guage and right hand indicator light not working which cured all of the above faults . Car was good for many months after unit replacement now this speedo fault. Could it be a case of instrument cluster gone again? Bad wiring? or an ecu fault
