Firmware upgrade
icchis
Hello
Can someone please send me the latest software update XE3953?
Currently it’s running on XE3809 and I’m experiencing problems with the FM audio. When starting the car, it forgets the pre-installed radio stations.
Big thanks in advance.
  • 2 months later...
On 3/13/2021 at 3:36 PM, flash22 said:
I am looking for updated firmware also . My is Yaris 2019 design hybrid (HE3945)
can you please to PM me ? Thanks
hello i have touch 2 gen 1 with XE3809 can somebody send me the last firmware?thanks in advnace
Hi everybody,
I read this post and if i understand, someone can may be help me to update the version on my Yaris.
I got the xe3864 version.
Any help will be appreciated.
Thanks in advance.
Jc
Hi @flash22
I have a Yaris 2015, could I also please have the latest software update for touch 2
Current one on my unit is on XE3809, model ID: 13TXDAEU-CA02
Much appreciated!
On 12/2/2020 at 11:01 AM, Fredpetrus said:
This is my version of the yaris software .
Should it need a update ?
Hi, Is there anyway i could get a software update? My My model version is 13TXDAEU-CA04 and the SW version is HE3947.
Thankyou for any advice
Hello @flash22
Please can you help?
The sound is very low when i am playing spotify via bluetooth. Also people say my voice on calls is very low. I have my phone device turned up to max and i have to have the car volume on about 28 to play music.
If playing normal DAB radio i put the volume down to about 10.
I have recently installed Alexa Auto and this runs via bluetooth aswell, but the connection constantly stops and starts.
I have a 2018 CHR and these are the versions of software & maps that i have:
I have read through lots of comments on here and i see that you often mention a hidden menu and also asking what BT version people have.
Can you tell me where can i find the Hidden menu and my BT version (if that's what's needed)
Could it be that i need a Software/Firmware update?
Or would you have any other advice on how i can make the bluetooth connection more stable and louder?
Thankyou very much in advance
Edit have you gone into general stettings and played you the sound levels ?
As you have a sat nav the module that takes control of the USB and bluetooth
you can try tuning the bluetooth
touch2 BT tuning codes.pdf
Here is how you access the hidden menu on the C-HR
Press the Vol/Power button so it displays Audio Off
Press the MENU button
Touch «Display»
Touch «Screen off»
Quickly press CH, 5 times  and immediately press TRACK, 5 times
turn the ignition off to exit the menu
go into function check and select HF Voice Quality Setting
Thanks a lot @flash22
I will give these a try later.
With the BT tuning codes it says to go into diagnostics mode. Is this where you have to press and hold the info button on the screen and flip the headlights on and off a few times?
that method doesn't work with the C-HR, see above
Hello flash22,
I got a toyota yaris from 2017
Softwareversion: HE3934
Device-ID: 13TXDAEU-CA04
Is there a new firmware available?
If yes, the current one is in German language. Is the firmware multilingual or do I need a German one?
Thanks!
Hello, my friend has Toyota Yaris 2012, the problem is, when the map appears, unit resets, when it's on the radio, everything is fine, any sugestion, all the best
touch updates are not available, the map updates are dealer only, iirc the last map update was 2021
it sounds like the nav module is dying (memory failing)
In this eleven page thread 🧵 are there any info about touch2 software upgrades for my 2023 Yaris hybrid?
I have 1 update for the touch2 gen 3, dcu it's 1413, a 2023 car should have a newer version from factory
As you have a sat nav the module that takes control of the USB and Bluetooth
you can try tuning the Bluetooth
Touch «Display»
Touch «Screen off»
Hi again @flash22
I cannot find "CH" and "TRACK". Please could you tell me where they are?
The "MENU" button i'm guessing you mean SETTINGS?
When you say "go into function" where is this?
Sorry for so many questions.
@flash22 Hi bought a used Yaris Hybrid 1.5 in Portugal and as far as I know I have the XE3809, model ID: 13TXDAEU-CA02
Both system and map seems very outdated, from 2015 it seems. My problem is that in-call bluetooth volume only goes down both from the volume knob and wheel buttons. Everything else seems to be working fine.
Is it possible to update it with a more recent available version in Portuguese?
Thanks in advance!
the blue touch buttons either side of the screen, my mistake that is the method for a different touch2 model
Function check is in the hidden menu
Thanks in advance!
Firmware is Euro/UK wide, so is multilingual
If you have sat nav you will have to swap the USB cable from the Nav to the DA
BT volume have you adjust the volume, in call and checked the volume level under general settings
Hey! Thanks a bunch for the file and information.
Believe it or not, after years of frustation, I found this menu just while I was waiting for your message.
I also download the 6.20 TLS update and the menu are now boxes instead of list as it was before, it seems to have updated the map, as I had 4.3.0, back in the afternoon 😅.
I wasn't able to update the DA yet as I don't have much expertise in cars overall, and don't have the appropriate tool to disasamble the radio to change the wires.
I'll buy it and try it later.
Thanks again, you rock!
Maps are a paid service, the TLS update, updates the base firmware of the nav module
So today I took a look again and saw that the screws could be remove with regular Phillips and I finally was able to update the firmware!
Now the bluetooth volume can be increased during the call!
Thanks again @flash22 for the instructions and files and @Dazaster for the pics of the wires to be changed/unplugged.
In my case the "OK" button wasn't lighting up with the same usb stick I used for the TLS update, it had only the firmware file. What I did was formatting again and putting the firmware file.
@flash22
The last part on here doesn't work:
Pressing > 5 times and then < 5 times just stays on the black screen.
Is there any other way to get to the hidden menu?
that is pulled from the manual, not all key presses register so you may need to press 6-7 times each
HI Flash22 is there an updated firmware version for the  unit below.
MODEL ID DCU 17TDT1EU-CA31
PARTS NO DCU 86140-K0272
VERSION 1393
Thanks in advance
