Firmware upgrade
icchis
Everything working fine now, many thanks flash22!
  • 4 weeks later...
On 11/26/2020 at 6:48 PM, flash22 said:
No problem Pm on its way
hey, can you PM me same firmwareplease? i have XE3934 ID 13TXDAEU-CA02.
my language it's italian.
thank you
Is HE3953 still the latest version? I went on Toyota-Tech.eu but couldn't find where these updates are.
Yes - 3953 is the latest and possibly the last for the touch2, as the gen 4 now uses the MM17
Thank you.
I have another slightly older non hybrid Yaris without Go.
The software says XE3809 and the model ID is 13TXDAEU-CA02.
Presumably that's not the latest version, if not how do i get hold of it?
Thanks again.
That firmware makes it a 2014- 2015 touch 2
XE3953 is the latest
I will pm you shortly
is it possible to get a firmware upgrade for a Yaris 2020 MXPA102013*** with a headunit 17TDT1JP-CA31 and audio 1315  ?
i do not have access to the MM17 firmware for the Gen 4 yet
thank you for taking the time!!
Hi.
I hope this thread is still live and flash22 is still around 🙂
I’m new Toyota owner and got a 2014 Yaris!
My problem is when I connect my iPhone it tells me that phone is not connected properly try reconnecting. However when I play music via Spotify, iTunes or anything it DOES play it. When tried it with my wife’s iPhone, which is an older model than mine, album art, artist, title all show up on screen.
I realized it might need and firmware update which led me here eventually. I have attached details of the head unit as a photo but still.
Software Version: XE3809
Device ID: 13TXDAEU-CA02
Thanks in advance and thanks for all the information on previous posts.
Hi flash22,
I have SW XE3934 and Model ID 13TXDAEU-CA02 on my unit.
I have a 2017 Yaris 1.33 Icon
Is there an upgrade for my unit please?
TIA
6 hours ago, WelshGasman said:
Hi flash22,
TIA
XE3953 is the latest this update sorts bluetooth and mp3 problems
Would you have a link on how to update please.?
I have the file on a new FAT32 USB stick, ready to go.
TIA
Start the car or put it in ready mode, Let the radio start insert usb stick it should pick up
Does the kwi file have to be the ONLY file on the stick?
I opened a brand new 32GB stick and put just that file on it, but it has a System Volume Information folder on it with two files in that, which I cannot delete.?
At present, it is not being recognised and is definitely FAT32.
Edited by WelshGasman
Format the stick in windows, even tho it's preformatted it may not be correct
You may have to go into the hidden menu and do a manual update
Press and hold the car button and turn the headlights on and off 3 times
Tap System information - program update
Not accepting it.
Tried another smaller stick (4GB) and still not recognised.
I know the USB port works as I have all my music on a 128GB USB stick and it plays fine, though I have been using bluetooth from my phone, since I bought a new phone.
I entered the hidden menu and found the Program Update, also saw the DA and Navi values.
It states to enter media, but does not enable the OK button.
I looked at Fault Diagnosis and the DA has Detail enabled and two codes, just the two codes, no dates or anything else
U0140
U0164
Did you clear the codes, if so did they come back ?
Both of those are failed to communicate
go into the other hidden menu and do a INIT (system reset)
Press and hold the settings button and turn the lights on and off 3 times, press and hold the INIT button for 5-10 second a prompt may then pop up
22 hours ago, WelshGasman said:
Not accepting it.
I noticed that the Touch 2 units are quite picky on the USB when it comes to firmware updates. Only true USB 2.0 sticks are recognized. Any USB 3.0 stick won't work (even though they work fine for playing music). FAT32 formatted is all it has to be.
I tried it with a 16GB USB 2.0 stick from Hema (so basically a cheap Chinese USB stick with the branding of a company that otherwise isn't invested in electronics).
Sorry, I not get any email about both replies above.
My first stick was a 32gb but Ubs3.
I then found an old 4gb Usb2 and will continue with that.
I was not able to clear the codes,
I will try the other hidden menu tomorrow.
Thank you both.
OK, got into the Diagnostic menu,
DA shows NG
Nav Box OK
I pressed the INIT button several times, it disables then enables, but DA remains at NG ? 😒
It is going in for a service next Thursday, should I mention this to Toyota?
TIA
Yes, tell the dealer, you have sat nav ??? That's why you can not update the firmware as the USB will be plugged into the NAV module
does the sat nav work ?? I guess not - that is the likely cause, otherwise it will show a map version and not a software version - That explains the communication codes - it may be worth removing the radio un plug it and plug it all back in
NG - Not good
TBH Act dumb and say the nav isn't working
NG - Not good
Sat Nav works, though the maps are 2016. I have my own Garmin Nuvi, so have used that as I have lifetime map updates for that.😀
Sorry I did not mention that initially. The unit plays mp3 files from the USB stick without an issue. That is even a 128GB USB 3 stick as well.
