Firmware upgrade
icchis
Hello everybody.
I am in France.
my girlfriend bought a yaris with the touch system without navigation.
The current version is the XE3934.
Do you have the latest update?
I managed to do the procedure to access the hidden menu.
I have the impression that his car receives fewer radio stations than another car.
Thank you in advance for your help.
On 9/12/2021 at 12:50 PM, flash22 said:
The update fixes a lot more than you think the main 2 are Bluetooth and MP3 playback inc the well known shuffle and track position/restart after key cycle bug
these systems are very complex, and very secure
I have noticed the "shuffle and track position/restart" happens on ours, I'm not sure what update I should use. Ours has the satnav and the current details are in the picture, can you advise what update I should use please. I have downloaded 4 from a previous post on here, I have one which is 13TXDAEU-CA84_9999.kwi, would that be the correct one for a Yaris with the satnav. I am put off by the CA84 bit as another one I have is CA82 (XE3953).
Many thanks
Hi, can you please send me the firmware update for touch 2. Thanks. Greetings.
@ashmj pm sent, this update fixes the issues you are having and is the correct one for the HE (silver buttons)
@MAXQ pm sent, that's never had an update
Thank you flash22.
I've now go the exact same problem as WelshGasman had. Need to do a bit more reading.
Nothing is ever easy.
  • 4 weeks later...
On 3/16/2021 at 11:55 AM, flash22 said:
I'm unsure how the mirrorlink is implemented, but you can try a DA update what requires the Nav module to be disconnected and the usb plugged into the DA instead of the nav
This method worked for me this morning. I finally managed to install the update. I hope it was worth it. Thank you flash22 for all the advice on this one.
  • 4 weeks later...
Hi flash22 and friends 🙂
I have Yaris Hybrid with he3934...
Is this the final/best version?
Can I update to a better version with mirror link? Thanks!!!
PM on its way - it has mirrorlink 1.0, but It's now a defunct standard very few new phones support it - no upgrades to AC or AA without using an interface box
Hi flash.
can you please check if there as any fw-Update for me ? 🙂B605B9B7-CBBF-4185-908B-9AB061B6B939.thumb.jpeg.35720a6868d549fed713d3003474708a.jpeg
Hi Flash22,
recently i purchased a Yaris 2015 MY with Touch 2 & Go multimedia system.
Software Ver: 4.3.0L
Map ID: 2014v2
Can you please check if there are any firmware & map update for my above system?
Best Regards
With Nav (GO) the update is part of the map - £120 from toyota - sign up for a My T account and register the NAV/Multimedia
if not, you can purchase a map through www.toyota-tech.eu
You know what, I don't think this update did actually work. When I do go back into this car the same song still starts off, Cutting Crew - I Just Died In Your Arms Tonight. I do like it but give me a break. BTW, the 12" version is brilliant.
The software version is showing as the latest.
Do you have the nav ? If so, what version ?
HE3953 is the DA update if you are using the nav it takes control of the BT and USB hence why you need to update the nav
Hello,
I am also looking for the ad hoc firmware to update my Toyota Touch 2 (without navigation).
The current version is XE3864 and the ID is 13TXDAEU-CA02.
Many thanks for your attention.
Best regards
  • 4 weeks later...
Hello @flash22
I'm looking for the new software for:
13TXDAEU-CA02
My current soft is:  XE3896
Thanks in advance for your help!
Best regards
Hello flash22.
Is some update for Yaris 2019?
Software version: HE3953
Without NAV
Thanks.
3953 is the latest and more than likely the last update as its EOL
Sad. Because there is still a problem with shuffling music. Instead of shuffling the usual random.
Hi there,
Is there an update for 13XTDAEU-CA02 system ?
1 hour ago, Damaelyon said:
Hi there,
what's the current firmware version or what year is the yaris
Hi Flash !
Thanks for everybody you've helped here
I have a 2016 Yaris, do i need an update ?  If yes, could u please provide ?
Thanks again !
Just had an update for the new 9" cloud system on the Yaris Cross, unlike the Touch 2 I had on my Corolla that took over an hour to install from a USB stick the Yaris Cross update took 10 mins to download and install.
Hi All I've got a 2015 Yaris and whenever I click bluetooth it does not do anything. the current software version is: XE3809 Model ID 13TXDAEU-CA02 can someone send me the files for a firmware update?
Also, when I click on the phone tab it says microphone disconnected.
Thanks 🙂
