Firmware upgrade
icchis
If in doubt, go into My vehicle - click on your car - on the right (top right of the picture of the yaris, click More, this allows you to add or delete the vehicle
Just to double check is this TLS 1.2 and i download unpack etc and then install before getting the Map Update 6.20.0L?
tbh it doesnt really matter i would do it after, just in case it's part of the map update
Thanks Bob for your help, tips to others as its taken 3 days, first make sure you have the right size usb pen, mine although it said 8gb on the pen the actual amount was less. I ordered a 32gb pen and flashed that and it worked, checking the 2 pens the lower one had less files on and even though it went through the set up, it didn't start counting down the files. Tip 2 download the free TLS file and do that first, then restart and check the device has changed, put the new version into the My toyota website and then download the free europe map update. I didn't have to pay anything. All updated now to the 2022 system and map. Looks different as there are tiles now.
 Hello Flash22!
I'm from Finland.
I have a Yaris Hybrid 2018 with version HE3945 and ID 13TXDAEU-CA04, no nav
I want to upgrade the software.
Can you send me newer FW and instruction how to upgrade.
Thank you
Hello Flash22!
I'm Attila from Hungary.
My Yaris is a 1.5 Selection Smart Blue 2018/7.  with version HE3945 and Device ID  13TXDAEU-CA04, no nav
I would like to upgrade the software.
Thank you!
Attila
Hey Flash22!!
I'm from Australia. Just bought a secondhand 2015 Yaris with model ID: 13TBDAOC-CA01, current software BA.36.17
Any music is awfully tinny sounding and completely cuts out any mid-range audio.
Would you be able to send me any software/firmware file updates?
Thanks,
Katie
Hi flash22,
I have SW XE3864 and Model ID 13TXDAEU-CA02 on my unit.
I have a 2015 Yaris 1.33
can you PM me firmware update please? i
6 hours ago, katie910 said:
Hey Flash22!!
Thanks,
Katie
Sounds like a blown speaker or 2 rather than a radio issue, Is that AUDM or JDM import car ?
Hi Flash,
I'm running Software version:XE3864 Model ID:13TXDAEU-CA02 is there a better firmware update for this as the car never recognises bluetooth media.
Thanks in advance for the help 👍🏻
3953 fixes a lot of issues you may want to check your BT settings as you can set it to connect to the phone only or phone and media
Hi Flash,
I have a 17TDT1EU-CA31  and the only version I see says Audio: 1257. I was wondering if there is anything newer.
Thanks in advance.
4 minutes ago, flash22 said:
Touch2 gen3 (Mk4 yaris) should update OTA
I may have, 1413
Don't think mine has OTA capabilities, unless hidden somewhere(?). I didn't mention, but I have no nav.
Regarding 1413, any noteworthy fixes?
Hello,
I have a 2014 yaris with the following:
Audio information:
Software version: XE3809
Model ID: 13TXDAEU-CA02
System information:
4.3.0L
Map ID:2014v2
From my e-store I can see that the latest update is Map Update 6.20.0L which costs 129 euros.
Any workarounds around that?
Hello from Greece. I have just bought a used Yaris 2017 and my software version is XE3934 with no maps. The device ID is 13TXDAEU-CA02.
As far as I am aware, there is also another final update. Where I can find it?
Thank you in advance!
hi i am from algeria new between you can you help me to upgrade my head unit
I have a 2017yaris with the following:
Audio information:
Software version: XE3896
I’ve just purchased a 2015 yaris. Can see in the thread that there is a firmware update. could someone please send me to where I can get it please
Hi guys, I have a Yaris 2015, could I also please have the latest software update for touch 2, currently on XE3809, model ID: 13TXDAEU-CA02, and also what is the procedure for installing it, many thanks
