Rear Lights Fuse
TeriBull Mechanic
Could someone advise where the fuse is located for the rear lights on 2006 Avensis D4D please? Both my rear lights no longer work (bulbs have been changed) so I am hoping its something as simple as a fuse that now needs replacing. All other lights (indicators, reverse, fog lights) work apart from the rear side / night lights. When I purchased the car I was told that there was no Manual. Any help and advise would be greatly appreciated as I am generally awful at anything like this am not afraid to give things a go! Many Thanks
Assuming RHD car it will be located behind the glovebox. Undo glovebox damper (one screw). Push in sides of glovebox and remove. I think tail light fuse is No. 14. Note that they activate via relay on this fuse board.  Do you hear the relay clicking when switching on the sidelights?
