Spring assistors
Hi all
Would anybody be kind enough to tell me what size of spring assistor i would need for a 2008 3 door aygo please. And where is best to source them?
Thank you.
Sammy
4 hours ago, eygo said:
hi Sam
here is a link for you
https://www.maypole.ltd.uk/Leisure/Leisure-Grayston-Spring-Assisters
why do you need a set of spring assisters on an aygo ????
has your other half put on some weight
Ahh cheers eygo...
However may i ask what im looking for on this site exactly please?
I cant seem to find info on what size id need for my original toyota springs
from what i can make out it doesn't go by car but by the gap you require to fill
i've watched a video and the assister is flexible and then cable tied to the coil
spring to stop it moving, when you used the link i gave you you'll notice
you dont fill in your car details it just lists the width of gap
here is another link it shows you how to calculate the size of assister needed
https://www.maypole.ltd.uk/Leisure/Leisure-Grayston-Spring-Assisters/ge13-grayston-spring-assister
Cheers eygo
I think ill have to jack up the rear
And actually measure the springs to be safe
Quick update, following advice on how to measure rear coil springs in relation to fitting spring assistors, we jacked up the rear today, and measured 3.7cm, possibly 4cm gaps in between each coil in the spring.
