2014 Invincible Brake Squeak
DebbieWinchester
Hi all - new to this and not very mechanically minded. We bought a gorgeous 64 plate Invincible (2.0) in February - used car from Hendy Ford. Within a few weeks we had a really bad grinding from the front brakes which they claimed were bedding in noises. Then when it became unbearable they took the brakes off and found a stone, they filed if that's the right term the pads and replaced. Noise got worse so they ended up replacing them - with universal brake parts! All along, there was also a squeaking noise at low speed/gentle braking.  Squeaking got worse took it back they did a bit more filing and so it went on. After the 6th visit they admitted to universal brake parts and ordered in genuine Toyota parts and replaced the front pads & discs. Squeaking subsided briefly but now after 4 weeks its back up to embarrassing levels (and now also happens when braking in reverse which it didn't do originally) - I've seen on a US site that this might be a common problem - does anyone have any experience of it or know anything about it please?
Was the work done under the Ford dealer's warranty or have you been bearing the cost yourself?
As I understand, there should be a pair of anti-squeal brake shims installed between each brake pad and the corresponding brake caliper. It 'sounds' as though these may have been installed incorrectly or even be missing altogether ...
