2005 2.0 Avensis Starting Issues
dforsdike
Hi
Recently bought a low mileage 72k Avensis, it had been sitting around unused for about 11 months.
When I picked it up I brought a new Battery with me fitted it and started fine.
Next day started fine took to MOt station and passed .
When starting again a few hours after this it wouldn't start, got someone to jump me , started fine went to place I got Battery from they tested it and said duff Battery. Have me a new one fitted it all good.
Next day same problem, I've been doing some research I think it's the alternator seized or not working.
There's a click when turning ignition so starter motor seems fine.
Now I'm no car mechanic so might be wrong anyone have similar experience or ideas of what's wrong
Thanks in advance
Sent from my SM-G960F using Tapatalk
It might be worth getting some sort of a cheap battery/alternator tester, just to see if you are getting a charging voltage out of your electrical system. Although, I would suspect that the regulator may be bad on your alternator, causing Battery damage. You can't rule out getting two bad batteries from the same source, even though it would be a very unlikely and unlucky thing to happen.
A click from the starter motor doesn't mean it's fine. Does it spin the engine? If not, then the solenoid built into the starter could be the culprit
