2015 t3 Prius adding cruise control
rual
Hi I’m looking at Uk model 2015 t3 Prius  ,
can anyone confirm the cruise control install method ,
apart from the cruise stick & plug in adaptor ,
is there more wiring that needs doing to Ecu
Or not
people  have done it ,
i just can’t find a easy instruction
thanks
rual Ahmed
I had a 2012 T3, got my dealer to supply and fit the switch.  I think they charged just under £150 including fitting and vat.
These are the part numbers they used:
  • COVER, STEERING    T45186-47030-C0
  • SWITCH, SPEED C    T84632-0F010
  • WIRE, CRUISE SW    T84633-05010
  • SCREW    T90159-50199
I've had the job done my them on a couple of Gen 1 Prius and a Gen 2 as well.
The Gen 1 and 2 needed a replacement brake-light switch above the pedal as they required an extra terminal to cancel the CC when the pedal is pressed, but later models didn't need the different switch.  The Gen 1 was the most expensive as it needed a different steering wheel to accommodate the switch.
No other mods to the cars was necessary, even the indicator light on the dash already had a bulb it it.
