Hi all.
After a little advice for my brother's 1999 Corolla 1.3 liftback. The car suddenly stopped running and cannot be restarted. He seems to think the VSS is faulty and wants to take it out for testing.
Having seen photos of the equipment that is in the way trying to access the sensor from above, is it possible to remove / replace the VSS from below?
Any advice would be gratefully received as it looks to be a booger of a job.
Thanks in advance.
Rattus
As no one has answered your question, Mick has a 1998 1.3 and has taken just about everything off his, so you could give him a PM.
His current post below, but you might find that sensor mentioned in his earlier similar   ' Paddy'  posts.
https://www.toyotaownersclub.com/forums/topic/174991-paddy-the-corolla-1998-13-e11-3-door/#comments
Thanks oldcodger. I will do that.
