ST205 - GT4 WRC Value???
Coxy77
Hi All
I hope you can help,, I currently own a neglected ST205  GT4 WRC.  import.  I am in two minds as too sell her as she is, or to continue slowly putting her back on the road.
The question is what is her aprrox value as is Vs road legal.
Here is the SP.
The Car has sat for almost 10 years, due to time and money constraints.
To give you some history this GT4 is a GENUINE GT4 WRC Car. The car is a Japanese import. I have owned the car since 2003 (i think) It was taken off the road in 2010 due to needing a new clutch and Suspensions set up.
Good Points -
• Opportunity to purchase a rare homologation Rally Car.
• Still fitted with the Factory Japanese limiter !! So this car to my knowledge has not been over 120 MPH
• Chassis is in great condition with no signs of rust. Engine removed in 2017 - New Belts, up-rated clutch, and Fluids fitted. 2017 - New BC Racing Coil-over kit fitted. 2018 Fuel Tank drained cleaned and fuel system flushed, New up-rated fuel pump fitted,.
2018 - Car started on the button first time once the fuel system was primed.
Bad Points -
• Partial Service history
• Obviously the car will need new Paint,
• Currently, the car requires new brake discs and Pads if the car generates enough interested at the right price, I may fitting pads, disc, and MOT.
• Tear in the right-hand bolster of the driver's seat.
• Some internal dashboard plastics have been cut to allow double din stereo fitment.
Thanks in advance
Mark
Moved to the Celica club.
