code p1604 and p1605. what does it mean ?
Ismail Yousuf
toyota yaris 2014 model
what does these codes mean
p1604
p1605
P1604 Startability malfunction This DTC is stored when the engine does not start even though the STA signal is input or when the engine takes a long time to start, and when the engine speed is low or the engine stalls just after the engine starts.
P1605 Rough Idling This DTC is stored when the speed of a specific cylinder becomes low and the idle speed becomes unstable. This DTC is also stored if the vehicle runs out of fuel. Be sure to check whether there is enough fuel in the fuel tank before inspection.
