Gearbox oil change
Edm
Hi
I want to change the gearbox oil in 2015 auris 1.2 T . But can't locate the drain or fill plug .can anybody help please
ps right hand drive
Edited by FROSTYBALLS
Topic title edited to reflect subject
Thank you so much Stephen . Can I ask do I have to remove plastic cover under car to get access to drain plug
Thanks again
Thanks again
Yes you will also I would remove the Nearside front wheel and remove the cover blocking the end of the gear box.
Makes it easier to see and less messy getting the oil in.
Remove the filler/level plug first.😎 Quite embarrasing if the drain is removed first and the filler is stuck! You are too.😐
  • Haha 1
