dash remains illuminated after ignition off check engine warning
angelicfront
I noticed a problem with my 1.33 petrol 2012 Toyota Auris when i turned off the ignition.
The dash lights remain illuminated and and the engine check warning or airbag check warning comes on.
Once you start the car and drive off, the problem stops but once the ignition is turned off the problem happens again.
The ECO RUN Converter has already been replaced previously for a similar problem (flickering dash lights with ignition off - technical service bulletin from Toyota BE-0070T-0514)
Anyone have any ideas
Many thanks
Was the part replaced by a Toyota dealer using a new replacement, or was a part obtained from elsewhere fitted? If already done by Toyota then I would think you have a genuine reason to have this fixed free of charge.
