Hello Guys,
I have a 2008 Corolla 1.4D4D E140 E15JE(A) and i´m in the process of changing the OEM radio for a OEM gps navigation unit. I already have the multimedia unit REF 86120-12B20 But i´m missing the antenna REF: 86860-12070 the cable REF: 86808-12060 the instructions manual and the navigation disk. So I would like to ask if any of you guys can help me getting these parts.
i´m living in the uk but the car is in Portugal so i´m comfortable with any deal in Europe.
Thank you all.
PS: this is IT
Have you thought of getting an Android based aftermarket unit which will come with GPS and you can then customize it however you wish like installing apps, etc. They don't cost a lot, but the gain is huge.
Koush
do you have any suggestion? I did Look around for those but they  seem tricky.
  • 5 months later...
Just to give you guys an update I was able to find the original gps unit for this car so I installed it and, because this unit has bluetooth connection  got an Toyota oem microphone as well! It works really good but because this unit doesn't have the 28 pin connector it was a real pain to find out where to connect the microphone!!!!
As you can see below the end result is really cool with the OEM look.
My only question to you guys is:
Does anyone know where can I find a connections diagram for this unit? I cant find it anywhere and is different from the ones I found over the internet because of the 28 pin connection. Over the net all I can find is connection schemes for the unis with the 28 connector, none for this one with 24! can You guys help?
Thanks A lot.
