Auris 2009 won’t start.
Vinny372
Hello, used a lot of threads in the past to help solve other issues but I’m at my wits end with my car now.
So its a 2009 Toyota Auris d.cat, was driving fine then suddenly cut out. Had it taken to my local garage. They diagnosed the injector driver was broken and needed replacing. Quoted £2000 for it in total.
So I ordered one from a Toyota breakers fitted it, still won’t start. Had a guy come to code the injectors, who ran diagnostics on the car, it had no faults and showed the injectors are working Correctly. Emailed all the results from the diagnostics it ran. But I still can’t get the car to start.
It turns over just doesn’t fire, he tried with easy start to see if that would help but it starts and immediately turns off.
Any ideas of what Could be the problem?
Sounds like lack of fuel in the system.
Maybe you have a blockage somewhere in the fuel line?
Changing the fuel filter is the simplest solution, i would start from there.
