Engine swap
Peteuk
Hi was wondering if anyone knows if the Avensis 1ad 2.0 diesel fits the RAV4 1ad on a 2006 plate ?
Something is amiss, What model of Rav4 as the Rav didn't get a 1AD 2.0 until Nov 2013 in the Series 4 model, a 2006 Rav could be a late Series 2 with a 1CD diesel or an early Series 3 but this only had the 2AD 2.2.
On the Avensis 2006 marks the change over from the early 2.0 1CD to the later 2.0 1AD .
The CD and AD engines are not interchangeable
Thanks very much for your reply Devon Aygo. I should have said the model originally was the 2AD CAT,but has had a 1AD engine fitted. This engine has had head gasket failure, been at a small garage for repairs,but couldn't get it running right after. In fairness no charge,but have it back now,started by doing compression test and noticed water firing out number 2 cyl. Engine removed so looking for replacement engine.
