Mysterious oil leak
Ole Dehlin
I got an oil leak out of the ac condenser and that should not be possible i think?
Is there any place in the system motor oil can pass into the ac system?
Thanks if anyone has a suggestion.
The AC system contains a small amount of oil with the refrigerant. Has the aircon stopped working? If the oil has leaked out, then the refrigerant has almost certainly leaked out, too. If the condenser has been changed in the past, then perhaps someone did an untidy job and never cleaned away old oil after themselves. Also, is there any chance some other system leaked onto the condenser or someone spilled oil?
