Posted (edited)
Does anyone know how to replace sidelight bulbs in a 2015 aygo. It used to be easy on the older models. Not anymore. Will I need to remove the headlight. Does anyone know which fuse they are on please. Many thanks
john
Edited by Skippyjohn
Saying please
Front or rear? Moved to the Aygo club.
Front sidelights please
Think they are covered by fuse 18 in the driver's side fusebox. The front position/side lights are LED's.
Do you mean the dipped beam (HIR2) ?
The front position lights are the LED strips which run along the base of the headlight unit - not the headlight bulbs, which in this case are HIR2's.
Yep DRL's - Just making sure the OP hasn't got there terms mixed up, I have come across it many times before with owners coming from older cars
No they aren't DRL's - these are located in the front bumper as separate units beneath the headlights.
john
The sidelights are sealed unserviceable LED strips,
