Poor fuel consumption
Mokhtar
Hi Every one. I have toyota Auris Excel hybrid 64 plate. I have feeled that the car has very low pick. Like when you have a very Heavy load on it. The MPG gone down to 31mpg. Any suggestions please.
Thanks.
Edited by FROSTYBALLS
Topic title edited to reflect subject
Have you a siezed brake caliper ?This would cause he engine / motor  to work under a greater load load to move the car. . After you have run the car look at the wheels is there a heat haze or carefully feel the centre of the wheel ( it might be hot ) This would indicate a seized brake .
My previous auris had 2 rear brake calipers changed due to piston /sliders stuck.
Steve
