Shaving foam trick
How to clean your windscreen with shaving foam
Take a clean towel and place a dollop of shaving foam onto it.
Wipe the windscreen with the towel, spreading the shaving foam over the entire surface.
Then take another clean towel and wipe off the shaving foam completely.
This protective barrier should help stop your windscreen from misting up, but it will need to be regularly reapplied to continue to work.
Also see:
