Rear Wiper Mechanism Removal
the_hood
Hi, the rear wiper of my Auris isn't working as it should. I'd like to gain access to the mechanism and see if I can find out what the issue could be.
Any advice on how to go about this? Just to add I'm a novice at this type of thing. Thanks.
There's an entrance hatch from inside the boot.
Open the boot, while the lift gate is in the air, it's easy to spot the hatch.
You can use this manual if you will need to replace it
https://www.autocats.ws/manual/toyota/auris_corolla_zze-zr-nde-ade/rm04f0e/repair2/html/frame_rm000002xjy000x.html
You could also share the actual issue with us, maybe someone had it already.
