DAB radio signal
toshtosh
We have had a few cars now with DAB radios and, other than a problem with a 2015 Toyota Yaris hybrid (relaced by dealer) get strong signals over most of the UK.
Our new(ish) 2018 PHV has a very weak DAB performance outside of the main cities but our main dealer says it is fine when they test it (In Bradford).
Has anybody else had problems with Toyota DAB reception?
Cheers
Tony B
Fine here... I use it in cities and in the country.
is it the touch2 in the Prius ? if so go into the service menu and check the dab signal and/or the diagnostics - I know it doesn't look the same but it runs the same system
It's slightly different on my Touch2 compared to those instructions.
Igntion in either accessory or ready mode. Hold media button, and while holding it switch headlights from Auto to Side Lights 4 times. Maintenance menu pops up...
