Hi, does anyone have a spec sheet for the Versa? I can find info on the 280 & 300 Hiaces, but hardly anything at all on the 250.
On a more general note, are there any links to handbooks or manuals?
I've looked on Toyota-Tech but not found anything.
That's a bit of an odd ball, is it a mini bus or is it a converted WAV, the 250 is the gross vehicle weight (2500kg)
https://media.toyota.co.uk/product_info/hiace-archive/
Edit. Can you PM me your vin number and i will look it up for you
From that vin the spec is..............
Model - KLH12R-RFMDHW (RHD) Hiace S.V.B
Engine - 2KDFTV High power common rail diesel (HDCR)
Built - 06/2008
Colour - 8P4 (dark Blue Metallic mica)
Trim code - FA15  (interior)
Body - 4DV (4 door)
Side Glass
Grade - S (european - DX)
Factory supplied as a 03s (3 seater)
I'm guessing Bob used toyoDIY or megazip..always a good tool to use for information relating to a specific Frame/VIN number.
Thanks for the info folks.  I hadn't come across ToyoDIY or megazip so took a look, very interesting stuff.
Is there anything that would give the design kerb & gross weights?
Also, are there any handbooks or owners / workshop manuals  online?
Don't know, is the short answer...but I would assume that there should some degree of Hiace model commonality.?
I have the epc (08/18) its a very useful bit of software, It covers about 98% of Toyota's worldwide
Curb weights and Gross should be on a label on the B Pillar as you open the door
Its Hiace S.B.V it's built as a minibus from factory - But I would think it will have common parts with the short wheel base vans
I've had a look around the online parts websites and am fairly confident that there's a lot of commonality so no worries on that score . Must say that I'm surprised I can't find any handbooks online, I've not come across this issue before with other makes. The Toyota website seems to only carry the latest vehicles that are in production.
