I have  techstream on my laptop, It connects to my corolla but brings up a long list of connection codes.
Which code should I select?
2019 Corolla 2.0 sport.
How old is your techstream? Considering the age of the car, maybe you need a newer version.
i think the latest one is around is early 2019 (14.20.019), unless you have it on subscription
Not sure what you mean by the correct code
the latest is here https://www.toyota-tech.eu/GTS/Wizard/step2-intro.aspx but it won't be a cracked version so you would need to pay the activation licence for the required period.
Been playing with techstream today (while sorting some technical issues with my install)
RE: Model code, the software should auto detect the car if not you put in the model code what is the first 3 letters of the model eg, NSP (NSP131L-CGFNBW)
NSP131L-CGFNBW is the full model code for a LHD Yaris GRMN
14.20.018 is the latest and is available (09/2019) up and running on win 10 x64 1903 after a little bit of fettling
14.20.019 is available
my bad it was a typo
Please delete this post wrong thread
I have the latest version. 14.20.019, with a key.
Using the meun DLC3  the CANH & L lines work, but the L and K lines do not.
