Hi working on a Toyota urban cruiser 2012 and after loosening the body side of the earth lead about 1mm to add a forked earth onto the Battery warning light has since been on. had it diagnosed at several garages with no fault codes found at all, charging and load voltage are perfect, no issue on alternator ripple test. Battery ampage is great batt is oem bought and only 1 yr old so in good life still. yet the dash board warning wont go out its day 5 and after short commutes with high usage eg lights blowers etc and it has not failed once to start  so beilive no faults are present . can anyone explain or has anyone had similar please????  many thanks
