Parking sensors wiring
Notebook
My partners son has the car at present but the reversing sensors have packed in. I understand that these were not an option when the car was new. Where should I look when I get access to the car.
looking to fit a new kit, but the existing keeps beeping in reverse so need to disable / remove it
thanks
If they were dealer fit, there is often an on/off switch mounted in the boot lining of the car - usually near to the light cluster containing the reversing light(s). Has your son inadvertedly knocked the switch to the off position?
It should be in the right side rear quarter you can find the fitting instructions on toyota tech, the on/off switch was an option
https://www.toyota-tech.eu/Aim/Aim2.aspx?pubtype=AIM&menuitem=2
its listed under park assist
if it's an older car it maybe an aftermarket kit then its a case of following the wiring
