2014 Yaris gearbox problem
Clonmaney
Hi my daughter has a 2014 1.3 Yaris car drives perfect but there is a slight noise in 4th and 5th gear nothing major but noticeable but when clutch is pressed it goes away just wondering is the gearbox starting to go or is it nothing serious any help will be much appreciated as she is starting to panic. And the car has only covered 55000 miles thanks in advance
Possibly clutch release bearing..but suggest you ask this in the Yaris forum.
Moved to the Yaris club.
If you bought the car in a Toyota dealership less than a year ago, they usually have a year warranty on their used Toyota’s. Otherwise my money is on a release bearing.
If the noise disappears when the clutch is pressed it's unlikely to be the release bearing.  If you can only hear it 4th and 5th it sounds more like a gearbox bearing to me.  As flash22 says, check the gearbox oil but if you find it low enough to make the gearbox noisy it's already too late!  If you are able to put up a link to a video of the noise it will help.  A vibration of some kind is another possibility but it's hard to tell from a description of a sound.
Release bearing ? But only in 2 gears 😩
5th is located at the highest point in the end of the gear box and is the most likely to be starved of oil first
edit, there may be some slop in the selector linkage/cables
Low oil level or incorrect specification oil used....  First check the level or get whomever services it to do so..
Check or replace gearbox oil, I'd replace. If the car drives OK i.e. the noise is not excessive, I'd just turn the radio up a bit.
  • Haha 1
