My camera is out of alignment following a rear bump.
Can anyone advise how to realign it please?
Many thanks
Cliv
You can't adjust it, the bumper is probably out of alignment after your bump. There is a screw in a speed clip, there might be very slight adjustment but it is minimal
if parts-king suggestion improves but its not quiet perfect then you could open up the mounting holes in the camera to give a little more adjustment
When the OE rear camera is fitted as an option, the complete rear diffuser panel is replaced. Presume the camera then just fits into the rear diffuser panel (camera).
