passenger footwell gets wet whenever it rains
plantpot01
Hi, I recently bought a 1.8 1998 Toyota Celica sr, however with the recent downpours I have noticed the whole passengers side of the floor is soaked, and was wondering if anyone could help out with the problem as I don't know what it could be, also it is defiantly water coming in and not coolant, any help appreciated.
Jordan
Hi, there are two likely ways for water to find it’s way onto passenger footwell. First one is from the A pillar and windscreen, somewhere alongside the rubber seal, you need to look for. Second common is to have water drainage holes blocked. Those are located somewhere under the Wiper Blades mechanics under the bonnet in the engine bay. You have to remove wipers, plastic surround and seal and try to find the holes. This happens to most cars especially those parked under trees and in a forest like conditions.
Good luck
  • 1 year later...
Hey guys! I'm having the same issue
.there was no holes under the windscreen wipers. Struggling to find out where the drainage holes are @plantpot01 did you ever sort the problem! Hope you  an help!
I'm not saying this is definitely the problem, but the rubber door seals tend to dry out and become inflexible as time goes by. This can lead to water leaking past the seal, as it doesn't do its job properly anymore.
Try cleaning the seals with a sponge, warm water and a little washing up liquid. Allow to fully dry. Then apply some of this stuff all along the seal (give the bottle a good shake first)
https://www.micksgarage.com/d/dash-rubber-and-plastics/products/2517984/gummi-pflege-stift-100ml?loc=gb&gclid=EAIaIQobChMIvruzjaLh7gIVh57tCh3fEA3jEAQYASABEgLk2PD_BwE
