Wing mirror
Nickems
Some idiot smashed into my wing mirror and it has come apart.anybody know if you can buy the housing on its own.
the cost of a whole new mirror is £500 plus apparently ,!,
I had a similar problem in May, when someone didn't bother to move to the left coming down a country lane. The mirror worked OK, but the casing was smashed.
The offside mirror casing came in three parts, plus the indicator LED (which worked, but with a broken fitting). I won't give you the part numbers, as they won't be any use unless you have a spirited aqua. The descriptions on the invoice are, as you will see, helpful.
Cover, outer mirror £35.14
Lamp assy, side turn £68.76
Cover, outer mirror £25.84
Cover, outer mirror £17.04
All prices excl VAT. Total, including VAT £176.14
I can well imagine the £500+ if the mechanism was damaged as well
