Replacing Front Discs And Pads
nhacchuongvui.ctv
Hiya all,
I'm about to replace the front discs and pads on my daughters Toyota Yaris (T3) 2003 (French build).  I noticed the front wheels were making a noise and now I've managed to take the wheel off I can clearly see the pads are worn.  I'm pretty confident doing the job as I was easily able to take the caliper off, however, I want to make sure I get the right replacement parts.
Measuring the disc it appears to be 235mm in diameter and the pads 130mm in length and 45mm wide. There is a mention there are two types of calipers so want to make sure I get the right one.
I believe the ones I should be getting are:
http://www.ebay.co.u...=STRK:MEBIDX:IT
Can anyone provide confirmation or further assistance in regards to replacing the discs and pads.  It looks easy but I haven't tried to take the discs off yet.
Many thanks in advance.
Nick
The securing screws on the disks tend to rust in. You need an impact screwdriver - and know how to set it up - easy -  and a lump hammer. Otherwise easy job.. Did ours about 10 yeara ago...
On 11/1/2019 at 10:36 AM, nhacchuongvui.ctv said:
Hiya all,
https://yeualo.com/view/cach-theo-doi-vi-tri-nguoi-khac-qua-dien-thoai-android
Nick
Thanks everyone.
