EPB automatic function not working
Gerald Walsh
Avensis T27.  2012
automatic function on the epb not working. The manual function does work.
Dash shows Check parking brake , Check ASC. Any help welcomed
Many thanks
Gerald
59 minutes ago, Gerald Walsh said:
Avensis T27.  2012
Many thanks
Gerald
I Googled Toyota Check ASC and result came back as 'automatic stability control'. The ASC isa linked with the ABS and traction control. I am guessing a sensor is not working, and has disabled most of the automatic functions, including the EPB. I think it might be the G force sensor. You need to get a diagnostics done, preferably Techstream.
I had a self inflicted fault where the clutch and G-force zero point calibration were accidentally wiped! I used Techstream to fix my problem. My other issue was caused because the gear position sensor was not securely connected and came adrift.
Here are links to some of the problems and possible fixes -
A lot of reading and I hope it helps.
