lighter problem
STAVROS1911
I charge my phone and stop charging...so I check in another car my charger is working..I check my lighter dosnt work in another car is working...I check the fuse under the pass driver is ok but anyway I change it with the same volt 15 I think...nothing again ...I check inside the hole to see if its something there...its clean....what can I do?the name of the fuse that I change is crg or crg..something like that...is another fuse somewhere for the lighter?or how can I fix it?I dont smoke inside the car
.i use only for charge mobile...help please
There are multiple fuse boxes in Auris, did you check all 3 of them? Inside the car should be (LHD car) on the drivers side, and other, on the right side, behind the glove box.
tou mean is 3 fuse for the lighter?I have right side drive car...so I found 2 boxes with fuse.one in front on the engine bit there is nothing about lighter and the other is behind the glove box...there is only chri fuse...
.on
Did you try to check the lighter for 12V using a multimeter, or similar?
I don't know what you mean by "chri" fuse.
sorry is cgr fuse....that means is the fuse for cigarette lighter....I use my lighter from my Toyota to my wife's car...Mazda and there is working...that means no power to my car lighter
Those lighters are easily damaged from day to day use. You need to take it out of the dash and inspect the wires are properly connected, than measuring if there any voltage coming to, and if yes put back all together. When you unplug the power consumables from the lighter make sure you do it with two hands , one on the plug one on the socket so you prevent disconnecting again. I found that trouble in few Auris already, so it’s worth having a look.
Regards
ok I will try tommorow...thanks
