2ZR-Swapped Turbo Yaris Project
06YarisRS
I recently finished installing a turbo kit on my 2006 RS 5-door. Before installing the kit, I swapped in a low mileage 2ZR-FE 1.8L Corolla engine. I also completely painted the car in my homemade cross flow booth.The car is an absolute blast to drive. When the car was dyno tuned, I had a bad BOV and a few small leaks and it produced 155 WHP at a max of 5.5 psi. Since then, I fixed the leaks, re-kitted the BOV, tweaked the wastegate and I'm hitting between 7.5 to 8 psi and estimate about 175 WHP with my new "street" tune which I did myself.
Here are links to a few threads that document the swap, paint process and turbo kit install. These are long threads.
2ZR-Swap
Repaint
Turbo Install
A quick (poor quality) video of merging onto the highway:
https://www.youtube.com/watch?v=80WPr7khL9k
Here are some pics from the project:
17 minutes ago, saxo265 said:
Welcome! 👍 very nice work.
Thanks saxo265. I enjoyed the build.
42 minutes ago, AL21784 said:
Good work that pal!
Alan
Thanks Alan!
