Squealing Belt when starting engine
holycrail
Hi Guys & Girls,
New to this forum but wanted to see if anyone has similar issues to the one i've experienced.
For about half a year now there has been this intermittent squealing noise upon starting the engine of my 07 E15 Auris. It's worse when cold but often happens when warm too and if i turn off the ignition and restart the engine within a second or two of turning the key then the noise immidiately dissapears. I'll attach a video as soon as i can to helpå diagnose thge problem. I cant imagine i'm the only person to have experienced this issue. Has anybody identified the problem before and knows what needs fixing?
The noise you are describing usually indicates a loose or worn ancillary drive belt.
Pretty normal, usually if you rev the car a bit, the sound goes away. You should change your belt. On auris it's pretty easy, so you can do it yourself.
There is a tightening screw on the alternator, use it to release tension and take the old one out, put new one in, and adjust until tight.
Any video or photo tutorials around?
Yes, sound like auxiliary belt squeal, and Auris has only one, so i doubt it's anything else.
I havent asked which engine before i wrote, but judging from the dash its gasoline, so i presume 1.6, so the instructions should be good.
Here's a nice instruction manual for 1ZR-FE engine (1.6 Auris 2007 gasoline), so i hope you appreciate the effort put into translating this
REMOVAL:
https://translate.google.com/translate?hl=&sl=ru&tl=en&u=https%3A%2F%2Fcorolla-club.ru%2Fdoc2%2Frm04f1ru%2Frepair2%2Fhtml%2Fframe_rm0000027io004x.html
INSTALLATION:
https://translate.google.com/translate?sl=ru&tl=en&u=https%3A%2F%2Fcorolla-club.ru%2Fdoc2%2Frm04f1ru%2Frepair2%2Fhtml%2Fframe_rm0000027im004x.html
REMOVAL:
INSTALLATION:
Thanks for your help. I replace the belt and provide an update 🙂
